Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 12-18-2008, 02:17 PM
TommySrt4 TommySrt4 is offline
Question Overboost problem
I just bought a 2005 srt 4 so im kind of new to them when i got it a sensor was blown out of the upper intercooler hose causing it to only boost 10 pounds and i fixed that and i was getting 14 and it was running good but then the wastegate stopped opening on it and it was boosting like 22 pounds with a 28lb spike and it started revving up on its own after you get on it. Today i went and drove it to work and i got on it in second gear and it only boosted 10lbs and as soon as it got past 4k rpm it jumped to 20lbs and spun the tires i dont know what is wrong with it all the vaccum lines are hooked up, The blue line coming from the selenoid is capped off i dont know if that matters or not. Any info will be helpful thanks
Old 12-20-2008, 01:42 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: Overboost problem
Have you tried resetting the comp?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 02-18-2009, 10:41 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Fix the damn wastegate... that's the obvious first step.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
