| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
transmission vibrating
just in stalled new fly wheel on my 86 foxbody mustang and know the transmissions vibreating
Re: transmission vibrating
Check your transmission mounts.
Also, I think it's possible to re-install the drive shaft 180* out of position from its original configuration. (Just going from memory here). If so, that can cause an imbalance and a vibration. Try unbolting the rear driveshaft universal joint and rotating to a new position and re-installing. You can also improve driveshaft balance by tightening a hose clamp around the driveshaft, and then moving it around until you see improvement. If it's not mounts or driveshaft imbalance, I'd pull the tranny and take a look at the flywheel installation again. Good luck and let us know what turns out.
Dave Westminster, MD USA |
