Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-17-2008, 08:30 PM
mike561 mike561 is offline
oil all over passenger side under hood
Just got the car running right again and after driving it for a bit i look under the hood and theres oil all over the passenger side of the engine, on the AC dryer etc. I just replaced the valve covers and gaskets, both the valve covers look dry, theres even more oil drenched under the car on the passenger side. I think the cluprit may be a bad timing chain cover gasket, i've wached it seep out from there before but never this bad, can valve covers still leak even if they look like they arent???
2006 Chevy Cobalt LS
Old 12-17-2008, 11:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: oil all over passenger side under hood
My best guess is that you have a section of valve cover gasket at the rear that's distorted/damaged or perhaps a wire got in the way and is 'sandwiched' between the cover and cylinder head. I've seen this before and it makes a mess.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-18-2008, 07:28 AM
I was thinking that could have happened too, im gonna take a closer look at them and possibly have to re-sit the gaskets in there
Old 12-18-2008, 11:30 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Also, don't over tighten the valve cover bolts or you could squash the gaskets and bend the lip on the covers. Especially if they are cork gaskets.
Good luck
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 12-18-2008, 05:33 PM
yeah i used cork gaskets
Old 12-18-2008, 08:20 PM
j cAT j cAT is offline
Good luck
this is the bad thing about cork....valve cover must be perfect where the mounting hardware goes thru....if its been over torqued and is bent it will continue to leak...
Old 12-18-2008, 10:37 PM
Im thinking of just using regular gaskets, which is the best kind to use?? the old valve covers' cork gaskets were baked onto the valve cover itself, that was another reason for replacement
Old 12-19-2008, 02:20 AM
silicon212's Avatar
Confoundingly Lucid
I quit using gaskets years ago. Valve cover gaskets are so .. 20th century ... LOL
I use Permatex "The Right Stuff". No leak in the 8 years since I used it.
Old 12-19-2008, 05:51 PM
Diddnt really know you could do that, did you have to slop it all on there or just use a thin layer?
Old 12-20-2008, 12:40 AM
silicon212's Avatar
Confoundingly Lucid
Just a 1/8" bead along the center of the gasket surface. It expands as it sits.
Old 12-21-2008, 11:43 AM
if the metal is cleaned with mineral spirits and you allow the silicone to set for 15 mins it is very effective...
this is method used to seal gear boxes where I worked and over many years the devices would rarely leak..
Old 12-23-2008, 05:44 PM
Found a little threaded hole at the front of the engine next to the fuel pump that sprayed out oil when i would give the engine heavy throttle, i think this may have been where it was comming from, i put a bolt in and drove around, i think i may have fixed it.
EDIT: heres a tech article on this problem http://www.rowand.net/Shop/Tech/Myst...evyOilLeak.htm
everyone should check and make sure that hole is plugged on your car too
Old 12-23-2008, 07:27 PM
silicon212's Avatar
Confoundingly Lucid
Oh yes, that bolt MUST be in place! If you took it out, now you know what happens.
