Old 12-17-2008, 07:08 PM
c180 c180 is offline
Oil level grows 99
72,000 miles cherokee sport 99 (works great) for some time the level oil is increasing after the 1,000-mile oil change, any ideas?
Old 12-17-2008, 08:28 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Oil level grows 99
Well, if the oil level is definitely going up, another fluid is getting in there.
If the oil starts to look brown/green and foggy, like a milkshake, then coolant is getting into the oil, through a blown head gasket or cracked engine block.
If you are driving on many short trips, without any long drives then condensation (water vapor) might be building up in the oil over time. The occasional long drive (1 hour or more) and/or frequent oil changes should address this problem.
Another remedy for condensation is to clean out the positive crankcase ventilation (PCV) tube. Unlike most cars, these Jeeps do not use a PCV valve, they use a 'metered orifice' which tends to get clogged over time. When this happens, harmful gases (including condensation) that build-up in any engine are not removed and contaminate the oil.
Old 12-18-2008, 07:24 AM
2000izusu 2000izusu is offline
also check for a stuck injector putting gas into the crank case. mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 12-19-2008, 08:28 AM
the jeep model is gas, the color oil no changes, only is increasing
Old 12-19-2008, 10:52 AM
MagicRat's Avatar
That pretty much rules out coolant contamination then.
Gasoline contamination can do this. It will dilute the oil without changing color. The problem is the oil becomes thinner and does not lubricate as well, possibly leading to engine damage.
Does the oil smell strongly of gasoline?
If not, consider an engine oil analysis. There are several sites out there like this one.
http://www.oaitesting.com/
Before getting a kit or sending a sample out, call them and ask if their kits detect gasoline or water contamination. It will be cheaper than guessing what the repair should be.
Old 12-19-2008, 02:32 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I've had good results with these guys:
http://www.blackstone-labs.com/
For free, they'll send you a kit to send them the oil back in. They test for contaminants in the oil, including coolant and fuel. I found a bad head gasket thanks to their testing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
