Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-16-2008, 11:10 PM
MochisTeam MochisTeam is offline
OBD Code P0169 Cutlass 1997
Could somebody help me to find solution for this issue ?
Previously error codes was P013A,P012C,P112B after clean them it shown P0169 code.
Mochis Team
Old 12-17-2008, 03:18 PM
maxwedge maxwedge is offline
A990 racer
Re: OBD Code P0169 Cutlass 1997
Welcome to AF. recheck the codes, no 0169 listed.
Old 12-17-2008, 06:47 PM
Thks for your prompt answer , the codes were read with Scan Master ELM 1.2A
P012C & P0169 again
I tried to send some pictures about measures but cannot .could you provide me an email address to send them ?
thanks
Mochis Team
Old 12-17-2008, 07:32 PM
A990 racer
There also is no code such as 0126? What definition are you getting on the scanner for the codes?
Old 12-18-2008, 07:20 PM
according with Codes I think P012X is related TPS
P0120 - TP System Performance
P0121 - TP Sensor Circuit Insufficient Activity
P0122 - Throttle Position (TP) Sensor Circuit Low Voltage
P0123 - Throttle Position (TP) Sensor Circuit High Voltage
P0124 - Throttle Position Sensor 1 Circuit Intermittent
And P0169 - Fuel Composition Sensor it´s shown in the scanner
Mochis Team
Old 12-18-2008, 08:17 PM
A990 racer
169 does not apply to your car. Tps is bad or has a bad connection based on the codes you posted.
