Old 12-16-2008, 10:46 PM
rev2red's Avatar
rev2red rev2red is offline
Send a message via MSN to rev2red
Trouble starting and stalling
2004 grand prix gt -The other day i tried to start car and it would turn over, was cranking good, just couldnt start, got a boost though maybe low battery cuz cold out and it turned right away. Then next day same thing but it wasnt battery. I hear fuel pump sending and i installed a KnN airfilter during summer and broke one of the module clips on the processor, i have to make sure it is down so it will start haha, i think that was problem, now at stopped position while idling it stalled out on me, it is also making a weird whinning sound when i start it and it get louder when i step on gas...PLEASE HELP
Old 12-16-2008, 11:22 PM
rev2red's Avatar
2004 gt crankshaft position sensor
engine light is on and says crankshaft position censor! this would cause my stalling and starting problems right? what about my whining noise? whinning when give it gas and turn wheel too. How much to change sensor?
Old 12-17-2008, 12:13 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: Trouble starting and stalling
If you can hear the whining in Park while revving, then I'd say the alternator. You need to put a fuel pressure gauge on the schrader valve to check the fuel pump. Could also be a fuel filter.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 12-17-2008, 01:43 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Why over think the starting and stalling? Your other post points directly to a CPS. Its not good to be driving around with a broken PCM connector. How did it break? Is it still able to make good connection? Maybe you should check this out and if it looks good then replace the Crank Position Sensor. Which by the way shoulndt run you any more than 50-60 bucks. Make sure you get an ac-delco replacement. It is an easy job thanks to our writup in tips and maintenance. The writup is for a series II 3800, but I dont think the series III is much different (if any).
Crankshaft Position Sensor Replacement '97-'03
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-17-2008, 04:56 PM
CrazyHorst CrazyHorst is offline
Is the "whining" a "growl" caused by low power steering fluid?
If so, please check and refill if necessary...if it is truly low and it is allowed to growl for too long that condition will become permanent until you replace the pump.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 12-17-2008, 05:16 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2004 gt crankshaft position sensor
rev2red,
Your two threads on what appears to be related issues have been merged together to cut down on confusion and possible redundant replies.
Timeslip 08/12/06
AF Community Guidelines
Old 12-21-2008, 08:26 PM
rev2red's Avatar
thank you all for help, and i broke one of the plastic clips while putting in a KnN gen lll intake, but the connection is still good! Could this cause a false signal to the sensors saying its the CPS when its only the processor clip?
Old 12-21-2008, 08:57 PM
tblake's Avatar
In God We Trust
Is the clip the plug that connects wiring to the PCM, or just a clip that secures the PCM to the car?
If its just a clip that secures the PCM, then chances are you need to replace the Crank Sensor.
Old 12-21-2008, 09:15 PM
rev2red's Avatar
its the clip that secures one of the 3 unites directly to the PCM, but all the prongs are in good condition and im thinking moisture maybe? but that wouldn't give the false reading would it bro?
Old 12-22-2008, 09:08 PM
rev2red's Avatar
yep its def. a PCM connection issue, everytime i can't start it, i pop the hood and wiggle one of the terminals and press down on it and it starts no problem, i still brought it in to mechanic to see if crank shaft position sensor was broken or debris build up or cover cracked or something just to be sure!
Old 12-22-2008, 11:59 PM
tblake's Avatar
In God We Trust
I hope you dont have to replace the whole terminal plug.
Old 12-23-2008, 09:33 AM
rev2red's Avatar
mechanic say i gotta change whole computer, cuz the terminal is broken! $600
Old 12-23-2008, 09:52 AM
BNaylor's Avatar
Is that Canadian or U.S. dollars. Obviously parts and labor in Canada is more expensive than in the U.S.
Is this one of the 80 pin electrical connectors located on the PCM module?
There should be two with 80 pins each.
Timeslip 08/12/06
Old 12-23-2008, 10:01 AM
wlkjr's Avatar
I'd check EBAY first.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 12-23-2008, 10:21 AM
BNaylor's Avatar
You have to be careful if it is the PCM module when shopping around for parts and there are other considerations with what might appear to be a simple replacement job. They are not plug and play in most cases. For one it must match his year Grand Prix which is 2004, the engine and all features/options supported. In other words unless it is from an exact same Grand Prix it must be programmed/re-programmed. The VIN number has to be programmed in.
The other option is just get a re-programmed performance PCM module from a U.S. supplier like ZZP, PFYC, etc. $99.00 (US). Some ship to Canada but there will be shipping costs and customs duties which will include getting the core back for the core deposit refund which is around $100.00 (US).
Timeslip 08/12/06
