Re: need ideas (94 DODGE CARAVAN)
Need more info. I'll take it when you say it will not start, you are saying when you turn the key the engine will not rotate. Are you only hearing a click or nothing at all? If you hear a click, the ignition switch, neutral start switch and starter relay are working. In that case you likely have a weak battery or poor battery/starter/ground connections or starter solenoid. If you don't even hear a click, your battery is very weak or dead or you have a bad ignition switch, neutral start switch, starter relay, starter solenoid or an open in associated wiring. Let us know those answers and do you have and know how to use a multimeter?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
