Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-16-2008, 06:29 PM
tinyman tinyman is offline
rpms???
i got a 87 s10 with a 350 and a th350 tranny. ok my tranny shifts at 4000 rpms when the pedal is at the floor. now shouent it shift around 5000-5500 rpm? i was told that my timing might be off, do you think that this is the case??
Old 12-19-2008, 02:02 PM
j cAT j cAT is offline
Re: rpms???
I would not go above 4000rpm...unless you what to kill the engine.
Old 12-20-2008, 12:51 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: rpms???
4,000 RPM redline? You don't know the SB that well, do you? The mild Grandma Grocery Getters can handle 5K, better factory ones can hit 5,500 with ease.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-20-2008, 11:27 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: rpms???
Shift points on a THM 350 are partially controlled by a vacuum modulator, If yours is defective, disconnected or hooked up to the wrong vacuum source (I think it requires manifold vacuum), poor shifting can result.
Old 12-20-2008, 01:12 PM
Re: rpms???
this 1987 s10 with the 350 engine is not original ...it must be an engine that came from an other vehicle.. like you say SOME 350 engines can go slightly above 5,000...rpm..
most of these S10's had 4 or 6 cyl. engines..
Old 12-20-2008, 03:45 PM
silicon212's Avatar
Confoundingly Lucid
Re: rpms???
You're right, no S10 ever came with a small block. However, the small block can handle 5k with ease.
Old 12-21-2008, 03:56 PM
Re: rpms???
where is the vacuum modulator located? or are you talking about my vacuum lines.
Old 12-21-2008, 05:06 PM
777stickman 777stickman is offline
Re: rpms???
TH 350 vacuum modulator is located on the pass side towards the rear of the tranny. Vacuum source needs to be from the manifold usually just behind the carb.
Also make sure the cable from the carb throttle linkage to the tranny is hooked up and properly adjusted.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-26-2008, 08:52 AM
Re: rpms???
because this is not a stock oem as built engine in this vehicle I would suspect that the detent cable on the throttle linkage may be out of adjustment .....
