Old 12-16-2008, 03:06 PM
BravadaGuy94 BravadaGuy94 is offline
Front Differential Problems ('94 Olds Bravada)
The front differential is toast on my '94 Bravada. I did not open the case to see what was wrong.
What I did do however, was take the front differential out of a wrecked '96 Chevy Blazer. They were exactly the same (outside appearance) as my Bravada with the exception of the 4wd actuator. I just swapped the trumpet housing and thought all was good.
I was told by the junkyard that it is the same, and GM originally told me the same.
However after installing the '96 diff in to the Bravada I experienced unusual loss of traction, and a quite noticeable popping noise.
The first thing that came to mind was the front diff was slipping, and that the gear ratios were not the same. I am trying to confirm this is the case, and what my next step should be?
I called GM again and they stated the gear ratios were not the same after all.
Bravada: 3:73
Blazer: 3:42
Can anyone confirm this? or at least point me in the right direction of what I should do next?
Thanks,
Nate
Old 12-16-2008, 04:30 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Front Differential Problems ('94 Olds Bravada)
Is it a AWD?
You can get in a world of hurt using a part time front end in a full time AWD.
And you will have to stay with the same gear ration front and rear
Is there a gear ratio tag on it?
MT
Old 12-16-2008, 05:20 PM
Originally Posted by MT-2500
Is it a AWD?
Yes it is AWD;
Why would it cause a problem using a 4x4 diff in an AWD diff?
They are the samething, other then the gear ratio in this case.
The only option I am seeing is finding ring and pinion with the 3:74 gear ratio.
The gear ratio tag should be inside the front diff, on the ring and pinion.
Old 12-16-2008, 05:55 PM
MT-2500's Avatar
AF - Advisor
Originally Posted by BravadaGuy94
Yes it is AWD;
4W and AWD have different cases and axels housing.
http://www.differentials.com/install.html
MT
Old 12-16-2008, 08:54 PM
Looks like they are the same, just like GM says... opcorn:
Old 12-17-2008, 03:41 PM
MT-2500's Avatar
AF - Advisor
If they are the same than why so much changing and many problems?
Get the right one and be done with it.
Good luck
MT
Old 12-17-2008, 06:25 PM
Good luck
Because they are a different gear ratio
