Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 12-15-2008, 11:01 PM
bruja423 bruja423 is offline
Question 91 buick skylark- need help please
what would cause the speedometer to suddenly go crazy while driving? with no warning it goes from one extreme to another, and will do this for up to a minute. the car will also chug and try to stall out. it doesn't always do it and there's no certain number of miles you have to go before it happens it seems completely random. the car starts up and drives fine other than this so what makes the speedometer go crazy and then makes the car want to stall?
Old 12-22-2008, 10:09 AM
Tom_SF Tom_SF is offline
Buick Owner
Re: 91 buick skylark- need help please
They might be two separate issues. The car conking out might be a vacuum leak somewhere. I'd check all those hoses and the PCV pipe too. I don't know about the speedometer. I'd worry about the thing chugging first.
Old 03-28-2009, 10:35 AM
Majets Majets is offline
I believe they are to separtate issue since I also had same problems on my 91 skylark--speedometer still does it(issue in the cluster not worth repairing since I know my car well enough to know my speed--shocking to people at times) the the stall/chug issue was repairable had to replace the 'brain'-ecm which is located under glove box easy driveway repair
Old 09-19-2011, 12:03 PM
jenhudd1171 jenhudd1171 is offline
Ok, sounds like the "brain" ecm might be my problem. I am new and just posted a question. Would you mind taking a look at my issue and see what u think. thanks!
Old 09-20-2011, 11:03 AM
Tech II Tech II is offline
Could also be the VSS....
