Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-15-2008, 09:30 PM
86foxbody's Avatar
86foxbody 86foxbody is offline
help with starting
ok i have an 86 mustang GT runs like a bat out of hell its so sick i just replaced the flywheel and starter it clicks and once in a long while it turns over
Old 12-16-2008, 09:17 AM
DurangoDave DurangoDave is offline
Re: help with starting
If you just replaced the starter, the first thing that comes to mind is bad electrical connections. Recheck that first. Check both the positive connection at the starter and check for a good ground path as well.
Second thing is check the battery - that's a classic symptom of weak or dead battery.
Third thing is a potential bad starter solenoid.
And last and least likely is that you received a defective replacement starter. You can pull it and bench test by using jumper cables.
Good luck. Let us know what solves it.
Dave
Westminster, MD USA
Old 12-18-2008, 08:48 PM
86foxbody's Avatar
the stater solenoid was bad
Old 12-19-2008, 05:57 AM
Dave
Westminster, MD USA
