Old 03-20-2003, 02:43 PM
juicyjuice juicyjuice is offline
Question 91' prelude si
i have a prelude w/ an idle problem. it revs up and down at idle. theres a sensor facing the car in front of the throttle body, coolant goes in and out. i had to have the lines brazed because of holes rusted through. could this thing be causing any of my problems? theres a screw on the end is this an adjustment screw? i need some help on this guys.
Old 03-20-2003, 03:10 PM
94civic's Avatar
94civic 94civic is offline
i think that is the tps-throtle position sensor(correct me if i'm wrong) and it is your problem fix the line and try again.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-20-2003, 03:17 PM
i fixed the lines some time ago, just wondering if i just need a new one. also being that it has run messed up should i reset the ecu? how do i do it? thanx.
Old 03-21-2003, 05:28 AM
i need help on this, i will hate to put in the shop if its easy to fix. does anyone have any ideas?
Old 03-21-2003, 06:44 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
sounds very much like your TPS sensor to me as well, replace that first, and see if it keeps hapenning.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-22-2003, 04:54 PM
OneSikCRX OneSikCRX is offline
Send a message via AIM to OneSikCRX Send a message via Yahoo to OneSikCRX
also if that doesnt fix it it could be an intake manifold gasket and you could try and spray carb cleaner around it and it will change the idle
Old 03-23-2003, 03:48 PM
where is the TPS located? not sure if im looking at the right thing.
Old 03-23-2003, 06:10 PM
xlosinghopex xlosinghopex is offline
Send a message via AIM to xlosinghopex
Are you positive it's the TPS? If not you might just need to change your air filter.
Old 03-25-2003, 08:13 AM
i took the wire off of the TPS and it idled fine just at a higher RPM.does anyone know if i can just get the sensor or do i have to buy the whole throttle body?honda says i've got to buy the whole thing.also is there another place to get it rather than honda? thanx for all ya'lls help.
Old 03-25-2003, 09:01 AM
crxlvr's Avatar
im pretty sure they arent sold seperatly, but check out www.hondaautomotiveparts.com also, they may have it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Prelude Muffler xxGriffonxx Prelude 1 04-30-2010 11:01 PM
91' prelude sr computer lights. Cory Johnson Prelude 2 08-18-2009 05:20 AM
WTB: H-series engine parts, P13 Auto ECU, '92-'96 Prelude DS mount CivicSpoon Classifieds 1 05-31-2009 03:58 PM
Best bet for a 91' Prelude Engine Swap?? gcbaine Prelude 2 09-20-2007 09:41 AM
