Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-15-2008, 10:55 AM
chiefmaka chiefmaka is offline
no start
I brought the car down from up north it ran fine. then one day it just quit running. I took it to a shop. they wanted 600.00 for a tune up. well i got it home did the tune up myself but didn't replace the cap and rotor. It still won't start. but it smells like it's getting too much gas too. Is it because it wont' start and it's just pouring gas in. Please help.
Old 12-15-2008, 11:22 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: no start
A complete tune up should include a cap and rotor also, maybe some plug wires also if needed.
Check to see if you have spark, sounds like you are getting enough fuel.
Good luck
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 12-15-2008, 12:10 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: no start
Sounds to me that the float is stuck, or the needle is stuck open. I've had a purge valve failure 5 years ago that caused the charcoal from the canister to work its way into the float bowl and this resulted in what you are experiencing now.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-31-2009, 01:12 AM
hypnotiz2 hypnotiz2 is offline
Re: no start
my 1977 caprice 350 wont start it turns over but it wnt start
Old 01-31-2009, 05:40 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: no start
I'd start with making sure your getting spark
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-31-2009, 08:32 PM
beat88ls's Avatar
beat88ls beat88ls is offline
Re: no start
well, i just went through the same thing. i even replaced the ignition module to no avail. i was getting spark (weak), and fuel but no boom. an old timer told me (and i laughed at him when he suggested this) that his 60s impala would do the same thing from time to time and he would take a heavy screw driver and thump the coil and would get it to fire... i ended up replacing the cap, rotor, and coil at the same time and it finally fired... then i did a full tuneup
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
