Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-15-2008, 09:49 AM
mickeydidit mickeydidit is offline
98 Rodeo 3.2 4x4
I am having a hard time getting it started.Everytime I turns the key I get one click.I takes about 4 or 5 try's and then it start's fine any suggestions.
Old 12-15-2008, 02:21 PM
palomo93 palomo93 is offline
Re: 98 Rodeo 3.2 4x4
I suggest you put some information up about your car. Did anything lead up to this? Have you had your battery tested? Have you had someone tap the starter while you tried cranking it?
Old 12-15-2008, 02:53 PM
I just bought it in may of 2008.Have not had anything tested.And I have not had anyone tap the stater while I tried to start it.This truck runs like a dream.No strange engine noise or anything.
Old 12-15-2008, 03:37 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I read in the info section on his truck that is has 204k.
I would start with cleaning up the terminals on the battery and the body grounds.
But it does sound like you have a classic dieing starter issue. (if 4x4 than you need to drop the exaust to get to the starter...)..
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-15-2008, 04:29 PM
Any check engine lights? If so, have you gotten them read? Any recent maintenence? Drastic weather changes?
I'd start by cleaning your battery terminals. Go to a parts store that can check your battery and alternator while it's still on the car (the best test is on the bench though, removed from your car). When I got my V6 Rodeo Sport it wouldn't start every fifteenth time or so. I took out the starter and cleaned the internal contacts and exterior connection points. It was easy to get at since it's a 2wd. That was 8 months ago and no problems since.
Old 12-15-2008, 07:47 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I agree with the starter being bad, not uncommon. But check the terminals first to make sure they are clean and tight.
The big problem with starters on isuzus are the contacts. They can be replaced. But you need to take the starter out to do it which is a HUGE pain on 4x4 rodeos.
http://forum.planetisuzoo.com/viewtopic.php?t=25205
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-15-2008, 10:33 PM
Cat Fuzz Cat Fuzz is offline
CLASSIC
starter problem. I'd bet pizza on it. The solenoid contacts wear out unevenly causing intermittent contact. The contacts can be replaced instead of dropping a load of dough on a new starter. Contact set costs about $15. Not just an Isuzu problem either. Any Denso starter is prone to this failure and that's the reason why 90% of them get replaced. Denso starters are used on a lot of vehicles.
