Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-15-2008, 09:05 AM
decmav decmav is offline
Cool Idling high
my 95cutlass supreme is idling about 2000rpm's and won't idle down,checked idle air sensor, pintle seems to be working back and forth and not extended to far and can't seem to find any vacuum lines off,would appreciate any feedback. thank you
Old 12-15-2008, 10:25 AM
maxwedge maxwedge is offline
A990 racer
Re: Idling high
Make sure the throttle linkage or throttle body itself isn't binding and closes completely, then focus on the iac.
Old 12-18-2008, 09:19 PM
Re: Idling high
thanks for taking tha time
Old 01-14-2009, 12:26 AM
88silveradoRWD 88silveradoRWD is offline
Re: Idling high
Also check into the THrottle Position sensor because if that is not working properly it will tell the computer you are opening throttle plate letting in more air which in turn will demand more fuel to keep the mixture at proper amount even though you are not actually giving any throttle. try disconnecting elect. connector to see if it idles down. If so replace sensor. could also try checking intake manifold for vaccum leaks. good luck
