Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-14-2008, 08:03 PM
stubrn stubrn is offline
Unhappy brain burn?!!
i have a 5.0 ho from a 94 mustang gt the wiring behind dash, gauges, pcm, engine harness, t-5 trans, crossmember, clutch assembly, exhaust and driveshaft. the 3 connectors other than to pcm behind fire wall are different than the t-bird. other than cross referencing wiring diagrams and splicing them together can someone tell me an easier way?
Old 12-16-2008, 07:49 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: brain burn?!!
Welcome to the forum stubrn. My answer to your question is no. You might get lucky and find someone that has done this swap to answer your question and tell you what wires to connect together but if not, you will have to cross ref the wiring yourself. The manuals are available on Ebay or you can try your local library to see if the have a Mitchell Electrical Manual for your year cars that you can photocopy the pages from. Here is an Ebay page with some manuals for sale for you to check out- http://shop.ebay.com/items/_W0QQ_dmp...nual&_osacat=0
Good luck with your project.
The Original 97Bird
Old 12-19-2008, 06:38 PM
Re: brain burn?!!
thanks i thought so. will the trac-lock from the mustang work in my rear? what is the gear ratio in a thunderbird by the way?
