Old 12-14-2008, 04:46 PM
briang0 briang0 is offline
94 Silverado low headlights no working
On my truck my low beam headlights do not work the High beams work fine. I thought it was the high low switch but tried to change it and it did fix it. I think the switch is working because it turns the parking lights and the high beam lights on and off. Any ideas?
Old 12-14-2008, 11:06 PM
rockwood84 rockwood84 is offline
Re: 94 Silverado low headlights no working
check your fuse box under the hood .there should be a relay or fuse for each headlight. should be a #10 amp .an '02 has a fuse for each running light. go figure . let us know in case someone else has the same problem..
