Odometer mileage
I had my instrument cluster replaced by the dealer on my 03' Silverado LT Z71. I checked my odometer reading and I think that they added 4K miles on it. Is this possible? How would I approach them about this?
Re: Odometer mileage
when you submitted your vehicle mileage should have been documented...compare that to the current mileage.. I also believe that the computer will store mileage as well ...so by checking the logged mileage to displayed may clear this.. |
On full size trucks the mileage is ONLY kept in the cluster. It is NOT kept in the PCM. http://www.gm-trucks.com/forums/inde...howtopic=80996 http://www.gm-trucks.com/forums/inde...334&hl+cluster Have a good one, Don
3/5 Cav, C Troop, Black Knights, Vietnam, 1969 |
but I do believe your odometer can be altered to show the correct mileage...if you have an odometer that is changed this is bad when selling the vehicle... to change the mileage the odometer is connected to a computer and with the correct software you simply dial in the correct amount... |
And yes your cluster can be reprogrammed. Any speedo repair shop can do it. You can get a cluster from E-bay and they will programme it with your miles and send it to you. They do not need your truck to do this. Have a good one, Don
thanks for that additional info.. If I had a problem with this I would most likely get this software and do it myself...
