Old 12-13-2008, 05:28 PM
88PA 88PA is offline
Replacing timing chain assembly
Hello, i been gone for quite a while. Since last post I've moved to Arizona from Ohio and the old 88 PA made the trip perfectly. I still have the service engine light due to code 41, I tried the glue in cam sensor idea but still have light so I assume it flew out from centrifugal force at start up.
The old gal has 160K with original timing chain. I'm gonna change out the TC assem. as well as the cam sensor, crank pos.sensor, gasket. Anything else I should change while there? Any special instructions or pretty much straight forward process?
BTW, AC pump went out during 120 degree Arizona heat and cost me 900 bucks to have replaced.
This is a great old car and I hope to run her for a long time.
Regards, Don
Old 12-13-2008, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Re: Replacing timing chain assembly
I believe there is a cam thrust button and spring also that should be changed, check into that also.
Old 12-14-2008, 12:27 AM
Hapynzap Hapynzap is offline
The U-Pull -it wrecking yards are full of these in Phoenix. You can bank some parts pretty cheap.
1999 LeSabre Limited - 154k
2002 LeSabre Custom - 145k
1985 Century Limited - 252k
Old 12-15-2008, 08:24 AM
Yes, if your refering to the chain tensioner then I have to buy 2 of them and return the one that doesn't fit. The parts store says there's no way of knowing until I tear into it. Do I need to pull the water pump?
