Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-13-2008, 02:04 PM
mwrealt mwrealt is offline
2000 regal coolant leak, back left on engine
I have a coolant leak in the back left area of my 3800 engine and it's not the water pump. It seems to start somewhere behind the alternator. Any ideas?
Old 12-13-2008, 04:13 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 regal coolant leak, back left on engine
Welcome to AF.
To start that area is classified the right side of the engine. Check the two coolant hoses that go from the tensioner assembly to the firewall and heater core. Also, check the two coolant bypass plastic elbows at the tensioner assembly to the water pump and lower intake manifold.
Timeslip 08/12/06
AF Community Guidelines
Old 12-13-2008, 05:57 PM
jerry1967 jerry1967 is offline
Originally Posted by BNaylor
Welcome to AF.
Is there any chance that the lower intake could be leaking there? Can you give me a picture of the tensioner assembly or show me where the two coolant hoses are that you are talking about.
Old 12-13-2008, 06:40 PM
BNaylor's Avatar
LIM is always possible so a close visual inspection is needed.
The pic below shows the tensioner assembly and the two heater hoses that go to the firewall and heater core. The alternator has been removed. Also, shown is the bypass elbow to the water pump. The red indicates the location of the three tensioner bolts. The other coolant bypass elbow goes from the tensioner to the lower intake manifold which can be easily seen.
Timeslip 08/12/06
Old 12-13-2008, 07:02 PM
thank you
