Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-12-2008, 11:06 PM
jeffrey9 jeffrey9 is offline
1990 suburban bogs down when i give it gas
i have a 1990 chevrolet suburban thatbogs down when i give it gas, have changed fuel pump. fuel filter, set timing , plug wires , drained fuel tank, changed injectors , changed coil , it starts and idles fine.
Old 12-13-2008, 12:00 AM
2000CAYukon 2000CAYukon is offline
Re: 1990 suburban bogs down when i give it gas
Need to verify that TPS and MAP are working properly. How is the compression?
//2000CAYukon
Old 12-13-2008, 12:56 AM
Could also be a restricted exhaust. If you remove the O2 sensor and drive it does the problem go away?
//2000CAYukon
Old 04-22-2009, 06:43 PM
suburbanstevie's Avatar
suburbanstevie suburbanstevie is offline
Had very similar situation on my '90 Suburban 454. Mechanic found that the distributor shaft journal bearings were shot. Put in a whole new distributor assy from GM (about $250), and suddenly had all the power I forgot I origanially had.
Good luck, Steve
