Old 12-12-2008, 10:17 PM
jbjslambert jbjslambert is offline
AC compressor noise
compressor making little growling noise when engaged. low on oil or freon? or compressor on the way out? thanks, joe
Old 12-12-2008, 10:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: AC compressor noise
It is important that you make your post as specific as possible. Please include the year of the vehicle, model, engine size, transmission type, mileage and any other information that may be helpful in trying to diagnose the problem. The more information you provide the easier it is for other members to help you.
Old 12-13-2008, 08:46 AM
oops sorry, thought that it wasnt that important on this issue due to all cars having a compressor. it 1997 lesabre 130,000. thanks joe
Old 12-13-2008, 08:59 PM
j cAT j cAT is offline
check the pressures first then remove the belt and check the pulley bearing...it is possible and common of a problem..check belt and idler...
I have seen low refrigerent, low oil, belts, pulleys,and bearings cause nosies..
growling noise is usually the compressor pulley bearing..
