Old 12-12-2008, 05:52 PM
2percent 2percent is offline
95 blazer prndl
My gear indicator light (PRNDL) doesnt work anyone else have this problem? Truck runs fine and all just doesnt light up or work. Anyone know how to fix this?
Old 12-13-2008, 10:30 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 blazer prndl
first thing is to get it on a engine/transmission capable scanner and see of the gear selecter switch is switching good.
If so pull dash and check plugin on back of it.
Lot of problems with the printed circuits in the dash.
Check with dealer and see if yours can be tested and or be rebuilt/repaired.
MT
Old 01-09-2009, 04:46 PM
Re: 95 blazer prndl
OK I am still having this problem I have no access to the scanner and I am currently out of work. So I pulled the cluster and nothing looks broken or burnt. And I cant seem to find power coming into it either.So I figured broken wire.. I would check the wires on the trans but cant seem to trace them without dropping trans. Is the anyway around this??
Old 01-09-2009, 05:23 PM
MT-2500's Avatar
AF - Advisor
Re: 95 blazer prndl
The gear selecter switch is on right side shift lever into transmission.
But you really need a scanner tomsee if it if working.
Factory repair manual or a all data online sub has the wiriging diagrams and test to run on it.
http://www.alldata.com/products/diy/index.html
MT
