Old 12-12-2008, 03:02 PM
MOTORSPORTS 1 MOTORSPORTS 1 is offline
Unhappy Remote Programming For 1995/96 Park Avenue
Looking For The Programming Instructions For A Park Ave With A Production Year Of 9/95. I Believe This Takes The Older Style Remote. Any Help Would Be Appreciated.
Old 12-17-2008, 06:57 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Remote Programming For 1995/96 Park Avenue
Notice the configuration of the ALDL connector when looking at it. When you look under the dash, it will be up-side-down & this is what you will see.
1994-95 Keyless Entry Programming Procedure
Note:
Before entering the programming mode, verify possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4 transmitters
1. Turn ignition switch off
2. Using a fused jumper, jump data-link connector terminal 4 to terminal 8
3. Press the Unlock button on one transmitter; doors should lock and unlock
4. If you have an additional transmitter for the car to program, repeat step 3, using that transmitter now.
5. Disconnect the jumper wire from the diagnostic port.
