Old 12-12-2008, 03:04 PM
jbbootlegs jbbootlegs is offline
Send a message via MSN to jbbootlegs
clutch noise escort mk6 1.8
hi wen i press the clutch pedal in it makes a noise, could it be the bearings and are they easy to change and expensive???
uk model ford escort lx 1.8 16v
thank you
Old 12-12-2008, 03:50 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: clutch noise escort mk6 1.8
Probably throwout bearing. Mine did that for awhile then got quiet again.
Nevada Tumbleweed
Old 12-13-2008, 06:46 AM
would you know if it will effect the mot??
Old 12-13-2008, 06:56 AM
and is it easy to sort out yourself,
Ford Escort LX 1.8 16v -UK
website
Old 12-14-2008, 02:16 AM
Davescort97 Davescort97 is offline
Escort guy
No it won't affect the mot. You'll have to remove that transmission to sort it out.
Selectron Selectron is offline
The MOT test doesn't involve the clutch, so no need to worry as far as that's concerned. I have the opposite symptom on my Mk.5b diesel estate - something is a bit noisy when the engine is idling in neutral with the clutch engaged (clutch pedal up) but when I disengage the clutch (clutch pedal down) the noise stops. I've never had to work on the Escort clutch though so I don't know much about it.
