Old 12-12-2008, 12:30 PM
2percent 2percent is offline
1996 Taurus wont start
OK I have a 96 taurus 3.0 that wont start. Motor turns fine getting gas and spark but will not even try to fire. It ran great before this it has 118,000miles.
No check engine light has ever came on or anything. I tried to jump it and still nothing. Throws no codes Im baffled thinkin maybe a camshaft positioning sensor of map sensor maybe??? Any ideas?
Old 12-12-2008, 03:20 PM
Doug Tatham Doug Tatham is offline
Re: 1996 Taurus wont start
If it's getting gas and a spark, it should start. There are three things needed for combustion, gas, air, ignition. Not many things will interfere with the air so I'd try a different means of determining whether or not it's getting gas and spark. Remove one of the front plugs, put the plug wire on it and ground the base to the block. Have someone turn the key and see if you get a spark across the plug. My best guess based on so little information is a bad coil. Check your fuel pressure if the spark is good. Check your fuses for parts to the fuel system.
Old 12-12-2008, 05:23 PM
Yeh the plugs get spark and its getting fuel not sure why it wont fire up. I mean the car ran perfect not one problem and now it wont start
Old 12-12-2008, 10:17 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
But to Doug's point, do you know that the fuel pressure is what it should be. How are you checking for fuel? Are the plugs getting wet? If it has fuel pressure and the injectors are working but it's not starting, the plugs should be wet with fuel after a couple seconds of cranking. One needed item for combustion which Doug left out is compression (and everything in the right amount).
-Rod
Old 12-12-2008, 11:18 PM
discnik discnik is offline
Make sure you have GOOD spark. Should be a nice bright blue not dull orange. Just for grins check your cap & rotor.
Old 12-14-2008, 01:15 PM
Ok good news i hope I got it started today kinda weird I had to push it out of the driveway to get another car and tried to start it. BINGO it fired up. But now has a miss my father in law is bringin the scanner over in a few hopefully we get it figured out today. Ill keep you updated
