Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-11-2008, 07:21 PM
D Bckyrd Mechanic D Bckyrd Mechanic is offline
Blower not Blowing
I have a 97 GMC Suburban, the rear vents blow air/heat. Nothing coming out of the front dash vents. Fuse under the hood looks good, what could it be?
Old 12-12-2008, 10:00 PM
aztecf aztecf is offline
Re: Blower not Blowing
its probally your blower motor, its located inside on the passenger side, right above where the passenger feet are. Put the blower on high and tap on it with a screw driver handle. It might start running. brushes might be worn out.
Jeff
Old 12-12-2008, 10:56 PM
Cusser's Avatar
Cusser Cusser is offline
Check to see if the blower motor is getting 12 volts positive when it's switched on. If so, replace blower motor. If not, troubleshoot the system.
