Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-11-2008, 11:15 AM
dk232677 dk232677 is offline
99 sl2 wont start
have a 99 SL2 that won't start. Have replaced the Temp Control Sensor and have replaced plugs. Hooked up diagnostic tool and that there were no "P" trouble codes.
Had coolant leak I believe from water pump and small oil leak. NEED HELP.
Old 12-11-2008, 12:12 PM
RC1488 RC1488 is offline
Re: 99 sl2 wont start
1. Check for spark. If you do NOT have spark at the coil towers, then the CPS is bad. It is common for it to start/no start on its own with out warning. Follow this video:
http://www.youtube.com/watch?v=pUMGFnK29B8
(This may also be useful :http://www.youtube.com/watch?v=Pv6wqQAmXvc)
2. If possible remove the spark plugs. Take a look at them and see what they look like. its possible that since youve been running rich they are black and will not fire the spark very well. New NGK will do well.
3. Fuel. I highly doubt this is your issue, but ill list it anyway. Put the key in the RUN position and listen for a humm. It should last 2-3 seconds. This indicates your fuel pump is running. Next, there is a valve on the fuel rail. You can press it with a small scewdrive and fuel should shoot out (its supposed to be around 38-40 psi so watch your eyes). If a decent spray comes out (not a drip) then the fuel pump is working. Sending your injectors to:http://www.witchhunter.com/ is good as they give your before and after reports.
4. You say you have new plugs. What kind? NO fancy kinds. NGK Copper is what you want. Any copper plug will do though.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 12-15-2008, 11:51 AM
When I changed the plugs (did get the copper ones), one of the old ones did have oil on it. Is that a sign of a head gasket problem? Since the temp sensor was bad AND I believe the water pump is bad, could that have caused the head gasket to go?
Also, is the timing belt a possibility?
Old 12-15-2008, 11:53 AM
Car uses a timing chain.
Oil can be from a leaky valve cover.
Is there spark?
A compression test will tell you if the head gasket is blwon or not. If you let the car over heat, this is a real possibility
Old 12-15-2008, 12:09 PM
i have spark
Old 12-15-2008, 01:34 PM
If you have spark, you need to check the fuel pressure. Should be around 38 PSI when the key is in the RUN position before starting. It should stay constant after about 10 minutes.
You can rent a fuel pressure tester from AA/AZ, or buy one for x-mas from harbor freight. Heard they were having a sale on them actually.
A compression check would also be very helpful.
