Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-11-2008, 01:13 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Ground locations
I'm still having some ignition problems. I want to check all the grounds. Does anyone know of any diagrams or anything that could help out with findind the locations of all the grounds?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-11-2008, 01:28 AM
discnik discnik is offline
Re: Ground locations
Foooooooooorrrrrrrrrrrr what type vehicle ????????????
Old 12-11-2008, 09:56 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Totally unnecessary. Clearly says "'99 Spyder 2.4 5-speed" in his signature. If it was for something else he would have said.
Anyways... in the haynes manual there's a bunch of wiring diagrams in the back that shows a lot of the major electrical systems. Show the grounds there. But that's all I know off hand.
What problems were you having?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-11-2008, 11:30 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
To find a ground I would just drop something like a coin or a pencil and see where it lands. That should get you pretty close, if not it will show which direction to look.
For my Talon it seemed like they were pretty easy to just look around and find, and they are one thing I am for sure going to do differently when I rebuild it. Pretty sure mine had one on each side of the motor if you know what I mean, front, back, and both sides.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-11-2008, 11:28 PM
Yeah I figured Id post up on here first. Ive been too busy (or lazy) to look at the car. Ive got a haynes, I will check that.
I doubt the problem Im having is ground related...well maybe it is, IDK.
Anyways, its a P0300 trouble code, multiple random misfire. Seems to be a pretty popular code on these ragedy cars. I found this huge thread on tuners with any amount of people having the same exact problem. Basically, the car skips and runs like duke based off of MPH. When I get up to 80mph is when it does it...I can let off and put it in neutral and let the revs drop and put it back in gear and its fine. Car runs good cruising though. I dont know what it could be. CAS, CPS, coil packs, ignition module...who knows. Im leaning towards the cam angle sensor. The only thing that gets me is that it isnt RPM related, because it doesnt do it through the lower 2 gears, starts doing it in 3rd at 80. Sometimes, I can pussyfoot it and get it past 80 and it pulls good again up until 110 or so. Its crazy.
Caleb
vanilla gorilla
Old 12-24-2008, 03:08 AM
Corrected the problem. I first replaced the cam angle sensor, which did nothing. Then i replaced the crank sensor and, that did the trick.
Caleb
vanilla gorilla
Old 07-23-2009, 04:05 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
The bad luck I have(which I always have) After rebuilding my engine and droping it back in I found out my crank sensor was bad....The only dang sensor we didn't change..lol
