Old 12-10-2008, 07:36 PM
Elliott000 Elliott000 is offline
Re: Top Dead Center -Distributor
Couldnt find where to start a new thread... but its along the lines of what you guys are talking about. 97 blazer, all fixed up just need to do the base timing thing, wheres my bypass... is it the plug on the dist. itself, then what do i do to adjust the timing. Yes i have a timing light.
Old 12-10-2008, 08:27 PM
old_master's Avatar
Advisor/Moderator
Re: Top Dead Center
This thread shows how to align the rotor: http://files.automotiveforums.com/ga...hp?photo=51302
You won't need the timing light.
Old 12-18-2008, 09:58 AM
Re: Top Dead Center
Thanks old master. I have it running and all is good, i just read alot about adjusting the "base timing" with the est plug undone. But if theres nothing i can do because they kinda adjust themselves then i guess im good. Thanx for the input
Old 12-18-2008, 01:51 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Top Dead Center
The timing is not adjustable.
But after you have it started and running you need to get it on a good engine capable scanner and set the camshaft retard setting by turning the dist to as close to 0 degrees - or + as you can get it.
Good Luck
MT
