Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-10-2008, 05:52 PM
mike561 mike561 is offline
Time for a new radiator
Pressure tested my cooling system today and discovered my radiator spraying out green, it seems easy to replace but i jus wanna know how to safely remove it without bothering the high pressure ac line that runs across the top, that doesnt have to come off does it?
2006 Chevy Cobalt LS
Old 12-10-2008, 06:09 PM
j cAT j cAT is offline
Re: Time for a new radiator
It should not be difficult.the ac line will move enough be gentile easy.
what is bad on radiator? I had a very large raditor with a 16psi cap, what I found was this pressure caused my tank seam to crack.when I replaced with 14.5 psi cap it never reoccured.
Old 12-10-2008, 07:22 PM
well i know the cap on my radiator said 15 psi, its the same cap ive always had on the radiator, so thats what i pumped into the system then i saw coolant seeping out on the coils, def diddnt wanna go any higher than 15 and end up blowing a head gasket or something :o
Old 12-10-2008, 08:31 PM
rhandwor rhandwor is offline
Pep Boys used to be close to what I paid with a garage discount. You might to compare their prices.
Old 12-10-2008, 09:48 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Should not be a difficult job, hardest part is disconnecting the trans lines, especially if rusted. Just spray them with some penetrating oil (the day before would not hurt). Should also use flair nut wrenches, those fittings are easy to strip with a standard wrench if frozen in place. If that happens, get the vise grips
I used a 3 row radiator when i replaced mine, i need the extra cooling capacity here in socal. Stock was a 2 row.
Don't forget the thermostat while you are at it.
good luck
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 12-11-2008, 07:38 AM
question about the t-stat also, when i replaced the thermostat housing there was no thermostat in there, why would they have left it out?
Old 12-11-2008, 11:55 AM
Blt2Lst's Avatar
Probably to nurse a failing radiator...
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 12-11-2008, 01:42 PM
If you live in a warm climate[it don't freeze] many don't install a thermostat or for that matter antifreeze...then they wonder why things are F**d up..
make sure that you drain the entire system and install at least 50% coolant and use high quality water best use distilled...
when the leak is at the radiator coolant tubes its from corrosion..
15 psi is stock cap ..I could not find aftermarket 15 so I tried 16 psi and this as I said is too high .thats why I settled for the 14.5 because that was available at that time.
Old 12-11-2008, 05:30 PM
yeah it def dont get down to freezing here (southern fl), you think i should just stay with the 15 psi cap then?
Old 12-12-2008, 10:25 AM
Blt2Lst's Avatar
That should be ok.
I would also use a 180 deg T-stat.
Al
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 12-12-2008, 06:07 PM
k i jus picked up a t-stat, might as well put one in while im at it
Old 12-14-2008, 01:17 PM
This certianly turned into a project, as i was trying to remove the t-stat housing one of the bolts were seized inside the manifold and snapped off, i tried drilling it out but it only got worse, now the hole is all mangled up and i am now getting a new intake manifold. i already got the carb removed. oh well ive been wanting to see how dirty the engine is under the manifold anyway, im expecting it to look like the bottom of a bbq grill, ill take pics when the manifold comes off.
Old 12-14-2008, 02:56 PM
and heres the inside, ALOT cleaner than i expected, im getting a new intake manifold and valve covers
Old 12-14-2008, 07:42 PM
the oil area looks very good ..the coolant area looks corroded...
Old 12-14-2008, 09:20 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
how much for the new manifold?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
