Old 12-10-2008, 02:15 PM
baman baman is offline
06 silverado p0449 code
I own a 2006 Chevy Silverado 1500 2WD. Just recently my check engine light came on. The night before I got the code my driver information center told me to tighten my fuel cap. I checked it and it was already tight. I took the truck to Autozone and the code p0449 came up. I have done some research and one of the first things I have done is change the fuel cap. I have also found out that on these newer vehicles if you top of the fuel tank repeatedly (which I have had a habit of doing) the fuel can acutally saturate the vent canaster. Apparently this is a fairly common problem with GM vehicles. One thing I am not sure about is that if the light came on while my fuel cap was already tight, what could that mean? I would appreciate any input anyone has on this topic.
Old 12-10-2008, 02:18 PM
maxwedge maxwedge is offline
A990 racer
Re: 06 silverado p0449 code
Welcome to AF, I am moving this to the proper Silverado forum below. Second, that code does not refer to a gas cap issue but to a vent valve or solenoid issue on the vapor cannister.
Old 12-10-2008, 05:58 PM
j cAT j cAT is offline
I have seen your problem with a 2005 sil. the owner would fill to max and then not drive very far ...this damaged the vapor cannister unit.
for him at the time it was under warrantee.
if you plan on parking the vehicle for a time do not fill tank to the max....esp on rising temps....it is possible this may clear as the charcoal gets purged..
Old 12-12-2008, 07:25 AM
I know that it may have been a total coincidence that my DIC told me to tighten my fuel cap the night before my check engine light came on, but I was also wondering if this could possibly clue me in on something. I would think that a tighten fuel cap message was some indication that my fuel tank lost pressure. What little bit of research that I have done on this topic, I know that there is some component in the EVAP system that is attached to the fuel tank. Could a malfunction in this component cause my fuel tank to loose pressure and cause the message telling me to tighen my fuel cap? I may be way off in left field about this...aside from routine maintenance I'm really not sure about the systems on these newer vehicles.
Old 12-12-2008, 11:54 AM
you are not supposed to overfill your tank...this will cause problems as you have ...
yes the tank has a very set computer controlled pressure /purge system so as to keep the tank at a slight vacuum....on shut down vapors get stored into the cannistor...If you overfill liquid gets sent to cannister this then causes problems like you have..it is not designed for liquid...this problem may go away with not over filling...as the vapor/liquid slowly gets purged from the charcoal...BUT it is written that if the cannister is filled with liquid it should be replaced..
the other components could also be damaged but hopefully not..
Old 12-12-2008, 12:09 PM
j cAT, thanks for the input. I have actually read somewhere that when the system fails, the majority of the time it is cannister or the hoses. Is changing the cannister something that someone with average mechanical abilities can do or would you suggest getting someone with some know how? This question is for anyone to answer.
Old 12-13-2008, 10:08 AM
I would contact the dealer . this is I believe a emissions componet that has a longer warrantee..
DO NOT SAY YOU ALWAYS OVERFILL THE FUEL TANK....
because of its location and the hoses it is not so easy a job...
on a lift it would be fairly easy...
Old 12-13-2008, 02:07 PM
A990 racer
Anything but the cat conv. and the ft engine pipe to the cat and the PCM have a limited warrantees of 3/36.
Old 12-16-2008, 09:36 AM
I was wondering if anyone knows what different year models and types of GM vehicles have EVAP parts compatible with mine? My truck is a Chevy Silverado 1500 2wd with the 4.8L V8. I am thinking about going to a junkyard to get the parts I need I may need. Hopefully they'll be good, and a whole lot cheaper than the dealer.
Old 12-16-2008, 09:52 AM
so you got price shock aye....someone has to bail out GM....
whenever the part is supplied by GM only,, the markup is about 300%...
I would give it some time to correct itself before spending any money..
with winter here later there may be some scrap yard parts ...
Old 08-11-2009, 08:15 PM
another GM satisfied customer....Its no wonder the clunker 4500.oo trade in didn't help GM.....most of the other auto manufacturers are doing Ok...
this is how GM operates...
Old 11-11-2009, 02:13 PM
vinson03 vinson03 is offline
Angry Re: 06 silverado p0449 code
hi everyone i have that po449 vent solenoid also dealer wants 267.00 for the part what a crock they dont even know what i really want i told them it's a small connecter circuit nad they say nope i agree with everyone on here that chevroley should pick up the bill for all these issues due to its mounting location they know all about it and even offer a NEW version and new mounting location..why should us consumers of chevrolet products bail them out of trouble if they dont want to do anythnig to help us gmc chevrolet owners out i think im gonna post gm see what thy say then i will post it here for everyone to see what they have to say..
Old 11-11-2009, 04:57 PM
this is something you must do...you will soon find the GM only wants your money..if they make a defective part/design they then jack up the price on the defect part cure..
I will be waiting for your results good luck....
Old 11-20-2009, 08:11 PM
rdeye1 rdeye1 is offline
Hello,
I am newto this forum, but repairs are rediculously expensive.
I have a 2003 4.8 silverado 4x4, my engine light went on, code p0449.
I am trying to find out where the EVAP solenoid is located.
Can you help?
Thank you
Rdeye1
Old 06-23-2013, 03:47 PM
fdmille fdmille is offline
I had a P0449 code on my 2008 Silverado crew cab and used ACDelco 214-2082 Canister Solenoid Valve Kit to fix it. I did not need to use 5/8 heater hose as others have used, because with a little bit of silicon spray and a bit of wiggling and pulling, I was able to get the original hoses off in reusable condition. However, I did cut off the hose connectors on the bad solenoid valve and crushed them in a vise, which made it much easier to get them out of the hoses.
The valve is located in front of the gas tank under the middle of the truck on drivers side.
