cyclinder 3 misfire
I have a misfire on cylinder 3.
had it checked and it only has 25 lbs. of pressure is there anything i can do besides having the engine taken apart |
Re: cyclinder 3 misfire
Please be sure to post the mileage, year and we are assuming you have the SII 3800 engine?
If that is engine compression the reading is unacceptable and sounds like tear down time.
So the valve guide's are bad its not ignition related did u crank it a enough and take off the other wire's to test smoother
check your cooling system for bubbles...headgasket failure can easily cause low compression....
Replaced upper intake manifold with an improved design that does not cause the EGR gas passage tube to warp the intake manifold. Problem solved and that was over 80,000 miles ago. I have talked to others who in addition to the above regasketed the lower intake manifold |
