4.3 won't run
Evening Folks, a little info on my prob. 94 s15 jimmy,4.3L W code 4x4 4spd auto cpi-repl due to leak fuel pump-repl took hike. fuel filter-repl map sensor-repl. Fuel press 55psi KO relay on,sometimes starts, no power idles ok will turn top rpm when run up slowly. bogs& stumbles when accelerated quickly. No SES or Codes. New cap rotor wires new cat pvc & plugs in oct.08 Ran fair for 120K miles until original fuel pump quit. Any assist gets attaboy award. Thanks ps get me outta this (wife's truck)
Re: 4.3 won't run
If the problem started with fuel pump replacement. Check that fuel pressure real good/Specs are 55/61 You should see 60 with load on engine running down the raod and 60 on cold cranking. If not work on that fuel pressure. If so go over secandary ign system. What is engine vacuum reding at idle and at 2K rpm?
Re: 4.3 won't run
Re: 4.3 won't run
I hope the gave you some discount for giving you the wrong part. If it is running good and starting good I would not worry about the TSB on change over. Good Luck
