Old 12-09-2008, 04:05 PM
foxlady99 foxlady99 is offline
Smile 2002 Grand Prix 2 problems
I just had this car in for repair today. They replaced the Pressure Control Solenoid, after they did a diagnostic, and it showed the code p1811. It also showed another code (can not remember this one), but essentially it is saying that the car is not warming up, and they believe that it is a bad thermostat. Also they said that the serpentine belt needs to be replaced. I know that on this forum is probably step by step instructions on how to replace the thermostat and the belt, but I can not find it. Can anyone out there give me step by step instructions, if so I would greatly appreciate it.
Thank you!!
Old 12-09-2008, 08:06 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 2002 Grand Prix 2 problems
What motor do you have in your GP? 3100 or 3800?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-10-2008, 05:39 AM
It is the 3800...
Old 12-10-2008, 10:41 AM
tblake's Avatar
In God We Trust
the t-stat in the 3800 is about the easiest you'll ever change.
Thermostat Replacement '97-'03 with SII 3800 Engine
We dont have a procedure in our subforum for the drive belt removal. You can try here and scroll to the 3.8 motor. YOu'll need a 15mm wrench on the tensioner. I always have to remove the strut tower brace (three 13mm bolts) and the coolant overflow bottle (2 10mm nuts).
Also this writeup might be of some interest to you....
Hard Upshifts, P1811 DTC, PCS (LOOK HERE)
Old 12-10-2008, 05:52 PM
Thank you so much. Hopefully with this help we will be able to replace the thermostat and belt before we start our holiday travels.
Thank you again!!
Old 12-10-2008, 11:05 PM
tblake's Avatar
In God We Trust
no problem. Good luck!
Old 12-11-2008, 12:58 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
only if its a 99' and up
Old 12-11-2008, 01:00 AM
oops...title says 2002 GP, wow I've been out in left field the last few days
Old 12-11-2008, 10:03 AM
tblake's Avatar
In God We Trust
I dont blame you at 1am. You must be addicted to AF Like me.
