Old 12-09-2008, 03:43 PM
willieray3 willieray3 is offline
99 Intrigue power steering return line
My power steering return line is rusted and is leaking in the front of the car. has anyone had this problem because I can't find one anywhere for it.
Old 12-10-2008, 01:14 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: 99 Intrigue power steering return line
Where have you looked ? I would think that most auto parts stores could get you the proper hose with no problem . You could try a Buick dealership parts department as the Intrigue is basically the same car as a Regal . Check them out !
Old 12-10-2008, 12:27 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
I would guess he probably has the 3.5 engine, and in that case your best bet might be a junkyard.
I dont believe you are talking about any sort of rubber hose, but that odd-looking angled piece of metal hose that comes in the top of the pump?
This is a good time to tell us which engine you have
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-10-2008, 04:15 PM
panzer dragoon panzer dragoon is offline
Napa or RockAuto.com, GMpartsdirect.com
Old 12-11-2008, 10:06 AM
Yeah it's the 3.5L I've tried Napa, Autozone, Murrays, Advance, GM Parts direct, they only sell the high pressure line (which I already replaced) the line is metal and runs along the front end of the car between the radiator and the lower air dam, it's used to cool the fluid but if I replace it with a rubber hose it wont cool the fluid. I live in michigan so the salt took it's toll on it and with 250k miles it's done its job. Has anyone had to replace thiers yet? and if so what did you do? Thanks
Old 12-11-2008, 07:45 PM
carbon02 carbon02 is offline
According to some files that I had access to a long time ago. Here is the procedure. Looks like quite a job for a hose.
Return Hose
Power Steering Return Hose Replacement
Removal Procedure
1. Remove the coolant surge tank and set the tank aside.
2. Remove the power steering return hose from the power steering pump.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly.
5. Remove the return hose from the clips on the frame.
6. Remove the power steering return hose from the retaining clips that hold the
power steering pressure hose and the power steering return hose together.
7. Remove the return line from the power steering gear.
8. Remove the power steering return hose from the vehicle.
Installation Procedure
1. Position the power steering return hose to the vehicle.
2. Install the return hose to the power steering gear.
3. Install the power steering return hose to the clips on the frame.
4. Install the power steering return hose to the retaining clips that hold the
pressure hose and return hose together.
5. Lower the vehicle.
6. Install the return hose to the power steering pump.
7. Fill the power steering system.
8. Bleed the power steering system.
9. Inspect the power steering system for leaks.
10. Install the coolant surge tank.
Parts Information
Part OEM Part Price
Power Steering Line/Hose
Line Kit
Right
5 - Without Variable Steering 26055484 $22.93
5 - With Variable Steering 26068609 $51.94
Order By Description.
Left
5 - Without Variable Steering 26065126 $50.71
5 - With Variable Steering 26031076 $8.99
This doesn't make sense to me. Maybe the return line is two separate parts?
The part number for the high pressure supply hose is
P/S Pressure Hose 26074656 $189.37 for those who may be interested.
Please get this confirmed before ordering any parts. This is all I have, and I haven't done that job.
2002 Oldsmobile Intrigue, 3.5L, GX --121,000 Miles as of 2/4/2011
2000 Oldsmobile Intrigue, 3.5L, GX --81,000 Miles sitting in garage awaiting shift kit P1811, and potential water crossover gasket repair.
Old 12-11-2008, 11:07 PM
just goto your GM dealer, look at the parts diagram, and order or get the part. -easiest way. With the part number, GMpartsdirect should have it also.
Old 12-12-2008, 06:58 AM
Those directions sound about right and there are 2 metal lines separated by a rubber line, unfortunately gm parts direct doesn't carry either metal line, I'll stop by the dealer next week and see what they show for it. Still curios thought to see who else has done this. Thank you all for your help!
Old 12-13-2008, 02:00 AM
Tobey Tobey is offline
Are you sure you're not looking at the transmission fluid cooling lines?
Old 12-13-2008, 07:45 AM
No it's the power steering line
