Old 12-09-2008, 03:08 PM
merrittjr merrittjr is offline
02 Cavalier wiper arm issue
The driver side wiper arm doesn't swipe correctly and goes all the way off the edge of the windshield. I can also grab the arm and move it without resistance. The passenger side is working perfectly. They were frozen on the windshield (I didn't know that) and the one went while the other one stuck. Easy solution?
Old 12-09-2008, 03:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 02 Cavalier wiper arm issue
Remove the arm and remove the aluminum from the stud on the wiper transmission with a sharp pick. Reinstall the arm and keep tightening the nut until the wiper arm no longer will move freely, then tighten it another 1/4 to 1/2 turn. I'd like to give you a torque for the nut, but I just go till it's "tight".
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-10-2008, 11:16 AM
muff34 muff34 is offline
torque....1/4 turn before it snaps..............lol. I put a lock washer on mine , seeing as how the fine threads on shaft and wiper arm were pretty much pooched.
Life Is A Highway ,Enjoy The Ride
