Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 12-09-2008, 02:57 PM
cavalier213 cavalier213 is offline
pistons
whats the difference between dish pistons and low compression pistons
Old 12-11-2008, 02:44 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: pistons
I don't really do any internal engine work, but here's what I remember from school.
Dish pistons are sortta dish shaped... they have a lip around the outside that is higher than the rest.
Low compression pistons just have lower compression than stock. Adding on forced aspiration could require the use of lower compression pistons if the engine has high compression already. I don't know of anything else they would be used for.
Dish pistons could also be low compression pistons.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-12-2008, 01:25 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: pistons
High compression piston 12.1:1
Stock Compression Ecotec Pistons 10.1:1
Low Compression Ecotec Pistons 8.5:1
Lower the compression ratio, the deep the dish gets. The higher the compression, the dish goes away and relief cuts are made for valves.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-13-2008, 07:30 AM
Re: pistons
so which one do you recommend me to use
Old 12-14-2008, 05:32 PM
Lifted GMT-360!
Re: pistons
Turbo charging - Low compression
Supercharger/rebuild - stock
N/A power maker - High compression
Old 12-14-2008, 07:06 PM
Re: pistons
can you tell me where can i get this low compression piston i will really appreciated
Old 12-14-2008, 09:45 PM
Lifted GMT-360!
Re: pistons
E-mail or call Karo @ www.carcustoms.net
He is one of the best j-body parts distrubutors around. When possible I buy everything through him.
email: [email protected]
phone: (818) 502-1073
Tell him Cody who works at RD Fabs recommended you to him.
Old 12-14-2008, 11:27 PM
Re: pistons
ok...ill do that but what compression ratio do i use
Old 12-15-2008, 12:08 PM
Lifted GMT-360!
Re: pistons
he special orders wiseco's, just request the low compression ones. They'll be in the 8's.
Old 12-15-2008, 08:11 PM
Re: pistons
ok ill do that...i was about to buy the 10:1 compression but my friends told me that i need low compression piston if im boosting my car nut i wasnt sure
Old 12-22-2008, 09:11 PM
Re: pistons
cody, karo said that there is no need to get the lower compression he said the 9:1 will be good
Old 12-23-2008, 01:50 AM
Lifted GMT-360!
Re: pistons
If the stock compression is 10:1 and he's got 9:1, yea those will work just fine. For your head gasket order a cometic MLS HG and get the thickest one they offer. It will also lower your compression a smidge more if you'd like.
Karo is the man.
