Old 12-09-2008, 02:27 PM
MKR602 MKR602 is offline
2000 Safari Brake Failure
I have brake failure when Im' applying the brakes and hit a bump at any speed. I do not losse the pedal they just don't seem to work.If I let off and reapply there fine.I saw another post that didn't go into detail or have a response. Any help would be appreciated
Old 12-10-2008, 06:12 PM
old_master's Avatar
Advisor/Moderator
Re: 2000 Safari Brake Failure
When this happens:
Does the "BRAKE" light or the "ABS" light on the dash come on?
Do you hear a rapid "clicking" or "buzz" sound from under the vehicle, (rear wheel ABS working)
Can you hear/feel the ABS pump when the front wheel ABS is working?
Old 12-10-2008, 09:25 PM
No lights come on, have not heard any noise,pedal feels different not soft just like being on ice.not every bump,not sure if it is when I hit a bumb on one side or the other
Old 12-10-2008, 10:31 PM
Vanfan Vanfan is offline
Did you check the brake fluid?
Old 12-11-2008, 01:41 AM
discnik discnik is offline
According to TSB 02-05-25-006B, if these symptoms are at low speeds the front wheel sensors pick-up coil surface and mounting surface need to be thoroughly cleaned. The sensors can be checked by removing the harness connector and ,using a DVM, test the sensor terminals for 350 ACmvs while spinning the wheel at hand speed.
