Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 12-09-2008, 11:37 AM
ocjlb ocjlb is offline
Replacing Head Lamp
I have pulled the driver side head lamp unit, wires and all, and need to replace the bulb. I think all I need to do is simply pull the bulb out, but it is being a bit of a bear and want to make sure that I am not going to break the thing! So, the question is, do I just simply pull the bulb straight out, or is there some other trick? Sorry for being dense, but I would rather be safe than sorry! Thanks...
05 Passat Sedan...
Old 12-15-2008, 07:04 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Replacing Head Lamp
you just push down the little bar tab deal and push to the side and then pull the bulb out.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
