Old 12-09-2008, 07:44 AM
Bdd8591 Bdd8591 is offline
Radio stays on with key out?
I have an 02 Lasabre and twice this has happened. Radio stays on and on the same channel. All I can do is pull the fuse under back seat and plug it right back in and all is well. Anyone know what's up or has anyone heard of this in other vehicles. It has a 3.8 in it if that matters. Thanks
Old 12-09-2008, 10:26 AM
Hapynzap Hapynzap is offline
Re: Radio stays on with key out?
Does the radio go off when you open the door? Mine does.
1999 LeSabre Limited - 154k
2002 LeSabre Custom - 145k
1985 Century Limited - 252k
Old 12-09-2008, 11:18 AM
brcidd's Avatar
brcidd brcidd is offline
Will the radio go off after 15 minutes? or like mentioned above- when door is opened? could be the door switch is inop as well- do dome lites work? Do electric windows still operate? Otherwise the delay relay is in control- as designed...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-10-2008, 06:31 AM
everything else works. The radio stays on with door open or closed and it will stay on forever if I don't pull the fuse and plug it right back in. Where is the delay relay located?
Old 12-10-2008, 08:02 AM
brcidd's Avatar
Next time it happens try pulling the RAP (retained accessory power) relay - Item number 46 in your rear fuse block- instead of the radio fuse- if this shuts off radio- then it may be the relay- you can swap it with another to test- other wise it may be being commanded on indefinitely......at least you'll have some direction.....
'99 GMC Yukon
Old 12-11-2008, 08:05 PM
spinne1 spinne1 is offline
Did you name your car Christine by chance?
