Heater core install
what do i need to do to install a heater core on 94 camaro..i beleive thats the problem after almost dying from antifreeze inhalation on the way home from my hour drive. no leaks on the ground. fine mist on the windows, i beleive its the culprit.
edit: its a v6 edit: or how can i bypass the heater core if the job is super tough
![]() car audio guru...
Re: Heater core install
you guys suck
You could bypass it for the time being if you don't need it. Not sure how much is entailed on a 4th gen, but I would imagine it's much the same that most of the dash has to come out. Look it up on Autozone's site, they have the repair manuals on-line, so you suck for not being resourceful on your own.
if its anything lik a 96 the entire dash doesnt need to come out, just take the glove box out and you can get right to the plastic air box that surrounds the heater core. Took me only 45 mins to an hour to do mine in a 96 rs. You could also use a 5/8 nipple and splice the two heater hoses together in the engine bay totally bypassing the leaking heater core.
4th gens are 1 million times easier than a 3rd gen, remove glove box, remove the plastic access panel, un-do connections on heater cor, and it comes out
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
nice to know that it's not that bad of a job.......i've had to flush crap out of my sons 94 2 times now from the crappy lifetime antifreeze......it's only a matter of time till i'm gonna have to rip it out.
