Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-08-2008, 07:31 PM
rodeowill rodeowill is offline
4x4 problem
Hi , I'll get right to it. I have a 99 rodeo 3.2 L V6 with 98k miles on it. I'm having problems when I'm running it in 4weel drive. At about 40 mph it will grind a bit and kick it into nuetral. I checked the fluids in the tranny, transfer-case, and front deferential. All seems fine. Checked tires and tire presure and there ok. The truck seems to run fine in 2 wheel drive. I never had this problem last winter.
Any advise?? What else can I check before taking it in to a specialist?
One more thing do any of you recomend me driving it in 2 wheel drive or will this cause more damege if it is something internall?
Thanks from Michigan. GO LIONS!!!!!!!
Old 12-08-2008, 08:18 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 4x4 problem
http://isuzufaq.ibctech.ca/#faq68
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-09-2008, 06:25 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: 4x4 problem
Also make sure you arent using 4wd on dry pavement, or even if its just wet. Only use it in low traction situations like snow, dirt, mud.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-09-2008, 08:10 PM
Re: 4x4 problem
Ok the problem is actually mechanicall. Not an easy fix. The transfercase needs to be rebuilt. Not cheap, but for those that don't know you can use a transfercase from an 98 till an 01 if you can find one.
