98 rodeo coolant leaking
I have a 98 isuzu rodeo 3.2 liter that I cannot figure out where I have coolant loss. I have replaced the thermostat, radiator cap, the two o-rings underneath the manifold, flushed the radiator, water pump and still losing coolant. Oh yeah, and the fan clutch. There are no external leaks that I can now see and there is no coolant in oil. The passenger side floor is not wet and I cant smell coolant inside the car so does that mean I can rule out the heater core? Can anyone please please help me cause im tired of buying coolant every other week. Thanks
Re: 98 rodeo coolant leaking
Heater Core?
maybe the Rad is plugged and is pushing it out the overflow?
have you tried a new rad cap yet?
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Your truck's getting up there on age, just like mine. I've had to replace tons of little coolant hoses in the last 2yrs due to rotting out, so take a GOOD look at your heater core hoses, oil cooler hose, cylinder head to cylinder head hose, there are a ton of little hoses on this engine that can leak coolant.
Also, if your radiator is original, along with your cap, these could be culprits too.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Since its a '98, also pull the coil packs on top of the plugs and see if there is any coolant in the plug wells.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
hello and thanks for your reply. Now if there is coolant in the coil packs would that mean a blown head gasket and shouldnt I see the milky oil at oil changes? Thanks
No, you won't always see milky oil at oil changes.
Reason for checking your spark plug tubes is the '98 model years are known for cylinder cracking issues due to a defect in the block design of the 98-99 model years.
Its actually the heads that crack, not the block. Either way is expensive news but heads are cheaper then a block at least. Makes me nervous since mine was actually built in '98, beginning of '99 model year.
So is there anyway I would know for sure that the problem is the heads besides coolant in the coil packs?
Thinking about using some of that liquid sealer...would anyone advise me to doing this and if so what kind should I use?
If you plan on keeping the truck then I would find the leak. You never know what will happen with the quick fix sealer. You can rent a cooling system pressure tester from Autozone to try and find the leak. Get a bright light and get under the truck. If you're not losing it through the exhaust or cracked head you might be losing through the overflow.
1994 Acura Integra LS---212K+ 1998 Isuzu Rodeo S 3.2L 2WD---176K+ |
Have you crawled under the truck to inspect for any coolant? If you can't find a leak, it has to be going out the tailpipe.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
If you find any coolant in the plug wells, check out THIS POST starting on page 2. If it turns out to be a cracked head you can PM Jerry (JLEMOND), he has new and used heads for sale. Always much better prices then going through other channels and he's a great guy.
I agree that if you dont see a leak its going out the tail pipe. Most likely a blown head gasket or bad head in that case.
Didnt find any fluid in the coil packs... so does that mean no cracked head hopefully? Gonna get under the truck today and do a complete check for leak. Oh failed to mentioned that had a pressure test done on the system and it was holding pressure.
