how do you flush heatercore
does anyone know how to flush the heatercore ...thanks
Re: how do you flush heatercore
use low pressures,when it flows freely you know its good... for some reason you will get a lot of debris stuck here... I do this every coolant replacement and the heater performance is super hot... |
thanks , ill follow those steps....the mechanic at my work said i have poor heat becuse the top hose is lukewarm and the bottom one is very hot going into the core
Is not flushing the heater the likely cause? Last year, it never blew really hot, just pretty hot to really warm. |
those lines to flush will be connected to the water pump btw
2006 Chevy Cobalt LS |
if this is the case [mineral deposits] then chemicals must be used or replacing the core... make sure the engine temp is not the problem first..there are a lot of defective new junk thermostats being sold now.. |
Reverse the heater hoses by switching them over and is another way to clean the heater core out.Another trick to new thermostats is to drill a small pinhole in it,a way to get rid of air pockets.
