Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-08-2008, 01:16 AM
aahz1969 aahz1969 is offline
94 town car dash codes?
I have a problem. I just replaced a fuel tank on a 94 Lincoln town car Limousine and now the fuel gage is not working and a digital dash code is present. The code is " CO " It will also not register any fuel and won't give any info on that account either. Does this code mean cut off for the fuel system? The fuel pump assembly is hooked up right and working but I don't know what else it could be. Is there a switch to reset or what? Please advise as to what to do to alleviate this problem. Thanks.
Old 12-11-2008, 12:44 AM
Towncar's Avatar
Towncar Towncar is offline
Re: 94 town car dash codes?
First.. if you have no fuel pumping.. yes - there is an inertia cut-off switch that can be tripped in the trunk. It's mounted on the left side trunk hinge assembly. What your describing sounds like the gauge sender unit isn't connect properly, or incompatible, or the harnesxs is damaged.
This is copied directly from your 1994 FSM.. you can have a free copy from my webpage.
FUEL GAUGE DIAGNOSIS
Condition(s):
o CO Displayed, Top Two and Bottom Two Diagnostic Bars Displayed
Possible Source(s):
§ Fuel tank sending unit.
§ EIC.
§ Circuitry.
Action(s) to Take:
§ Go to «Pinpoint Test BA» .
o CS Displayed, Top Two and Bottom Two Diagnostic Bars Displayed
o Inaccurate Fuel Gauge Indication
Pinpoint Tests
PINPOINT TEST BA: CO DISPLAYED, TOP TWO AND BOTTOM TWO DIAGNOSTIC BARS DISPLAYED
² BA1: CHECK FUEL PUMP WIRING AT FUEL PUMP
² BA2: CHECK FUEL PUMP
² BA3: CHECK FUEL PUMP WIRING AT EIC
BA1 CHECK FUEL PUMP WIRING AT FUEL PUMP
l Disconnect battery ground cable.
l Lower fuel tank to gain access to fuel pump connector.
l Unplug fuel pump connector.
l Jumper variable resistance terminal and ground terminal of fuel pump connector.
l Reconnect battery (10653).
l Turn ignition switch from OFF to RUN.
l Check digital fuel remaining display to determine whether it shows CO or CS.
NOTE:
It may take several minutes for the fuel gauge to respond.
l Does fuel gauge display show CO?
Yes
GO to «BA3».
No
REMOVE jumper. GO to «BA2».
BA2 CHECK FUEL PUMP
l Turn ignition switch to OFF.
l Measure the resistance of the fuel tank sending unit at the fuel pump terminals.
l Verify that the resistance is less than 181 ohms (normally between 11 and 168 ohms).
l Is resistance less than 181 ohms?
Yes
INSPECT fuel pump wiring connector female terminals for flash or loose fit. SERVICE as required.
No
REPLACE fuel pump. REFER to «Section 10-01».
BA3 CHECK FUEL PUMP WIRING AT EIC
l Remove connector J1 from EIC and secure connectors from shorting.
l Jumper variable resistance terminal and ground terminal of harness together at fuel pump.
l Verify continuity between Pin J1-2 and Pin J1-4 ground of EIC connector.
l Is resistance close to zero ohms?
Yes
REPLACE EIC. AFFIX odometer sticker to door pillar.
No
SERVICE fuel pump wiring for open circuit.
GENERAL INFORMATION:
Fuel Indication System
Fuel Gauge
The fuel gauge operates in the following manner:
l Fuel level is displayed on a digital bar gauge, using 14 bars from top to bottom.
l An additional two-digit display (on the message center) shows the approximate amount of fuel remaining in liters or gallons.
-- For fuel levels greater than 70 liters (18 gal), the letter F (full) is displayed.
-- For fuel levels less than 3 liters (1 gal), the letter E (empty) is displayed.
l Liter or gallon values are selected by the English/Metric button located at the lower RH side of the instrument cluster.
l The digital displays are based on a varying current flow from the fuel sending unit and fuel pump (9350).
-- When the fuel level is low, fuel sending unit and fuel pump resistance is low.
-- When the fuel level is high, fuel sending unit and fuel pump resistance is high.
The fuel pump symbol is always on except during:
l Check-out sequence - on/off/on.
l Low fuel level warning - the fuel pump (gas pump) symbol flashes when approximately one-eighth of a tank of fuel remains.
Diagnostic Bars
Diagnostic bars perform the following functions:
l When only the top and bottom two bars appear on the fuel gauge, this indicates that the resistance of the fuel tank sending unit (9275) is above or below the operating resistance range (above 168 ohms or below 11 ohms).
-- Either an open or short circuit is present. (Refer to «Diagnosis and Testing» section).
-- CO for circuit open or CS for circuit short will be displayed if Digital Fuel Remaining or Distance to Empty function is selected (refer to Diagnosis and Testing).
l There is a built-in delay of approximately 30 seconds from the time the circuit open or short occurs until the diagnostic bars appear.
l This is to prevent momentary sender intermittent conditions or circuit noise from triggering the diagnostic bars.
Low Fuel Level Warning
A low fuel alert is given by a flashing fuel pump symbol when the fuel remaining is approximately one-eighth of the tank.
Fuel Sender Unit
The fuel sender unit, which is combined with the fuel pump assembly, operates in the following manner:
l The unit consists of a variable resistor controlled by the level of an attached float in the fuel tank (9002).
-- When the fuel level is low, resistance in the fuel tank sending unit and pump (9H307) is low and number of lit bars is minimal (from EMPTY position).
-- When the fuel level is high, the resistance in the fuel tank sending unit and pump is high and number of lit bars is greater (from EMPTY position).
NOTE:
The filter used on the fuel pump assemblies is not serviceable. Should it become clogged or inoperative, fuel pump must be replaced.
-Steven
1996 Town Car, Cartier
