Old 12-07-2008, 10:08 PM
NoChevy NoChevy is offline
Angry Mustang won't heat
Have a 2001 Mustang with a 3.8 V-6 that won't heat. Even though the temperature gauge is at the normal level for heat, it blows cold air. IF it does start to blow warm air, as soon as I stop (like for a stop light) and sit for more than a very short time, the cold air starts to blow again. The thermostat appears to be working properly and I have flushed the heater core. Water flows through easily. I have never seen this problem before and so far no one has any ideas. Has anyone else had a similar problem?
Old 12-08-2008, 02:13 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Mustang won't heat
Its probably the air door. There is a door in the heater box that selects cool outside air, or air from the heater core. If that door isn't working, no heat.
Dragging people kicking and screaming into the enlightenment.
Old 12-08-2008, 01:51 PM
Thanks -- I'll check that out!
