Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 12-07-2008, 07:00 PM
nytlife666's Avatar
nytlife666 nytlife666 is offline
Send a message via AIM to nytlife666
Stop Light Problems
I just bought my first cadillac (94 Deville 4.9L) a buddy of mine noticed the other day that my brake lights werent working. My third brake light and the tail lights dont come on, though at night the lights come on just dont work but dont become brighter when my foot is on the pedel..ive researched threads on here and seen that it my be a brake light sensor/ stop light sensor? Would this be correct?
1992 Plymouth Laser RS
-Ground Control Springs
-SWP Front Sturt Bar
-JSP Apache Wing
-Tanabe Muffler
-Painted Taillights
-Eclipse 5444
-AutoLoc Shaved Door Kit (35lbs)
Old 12-07-2008, 10:48 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Stop Light Problems
Yes, there should be a brake light switch mounted just above the brake pedal itself.
You would want to test this switch before replacing it. It should have 2 wires. One wire should have power when the engine is running (brake not depressed) and both wires have power when the pedal is depressed.
Post back here with the results of the test.
If the switch checks out okay, the problem is elsewhere. If there is no power to the switch, check the appropriate fuse.
Old 12-08-2008, 06:01 PM
nytlife666's Avatar
Ill post back 2maro ended up gettin back to late from work. I love this car im just having alot of problems arising now . Pretty sure the cv joint needs replacement on passenger side, a believe i have a vacume leak because my heat stopped working along with the cruise control. Thank You though deff let you know about the switch 2maro.
-JSP Apache Wing
-Tanabe Muffler
-Painted Taillights
-Eclipse 5444
Old 12-08-2008, 06:04 PM
severence severence is offline
you're going to get pulled over and get a ticket.
american cars suck
nytlife666's Avatar
I checked the fuses before anything and bulbs ha
-JSP Apache Wing
-Tanabe Muffler
-Painted Taillights
-Eclipse 5444
Old 12-08-2008, 06:15 PM
nytlife666's Avatar
Thanks for the heads up
-JSP Apache Wing
-Tanabe Muffler
-Painted Taillights
-Eclipse 5444
Old 03-18-2009, 05:25 PM
nytlife666's Avatar
wasnt the sensor though idk if any one knows what this is but im gonna explain..In the tail light bezel there is a wire below the brake light buld (black rubber peice, has a wire inside that is inside a plastic tube). The passenger side one wasnt in all the way i pulled them out cleaned them and replaced, well i now have brake lights durring the day but at night they dont become brighter. Any one have a clue?
-JSP Apache Wing
-Tanabe Muffler
-Painted Taillights
-Eclipse 5444
Old 04-07-2009, 10:03 AM
corem corem is offline
Send a message via MSN to corem
Are you surethe ground is good and try testing the socket that the bulb goes in with tail lights on. A good test light should work. You may also need a voltage meter so you can get idea of the voltage back there should be battery voltage.You should have two hots and a ground .
