Old 12-07-2008, 05:55 PM
garbageman_262 garbageman_262 is offline
Lights Out
I have a 2003 GT and im wondering if there is anyway to make my lights only on the switch! i want to be able to shut the lights completely off!!! i figured out how to shut the headlights out but the parking lights stay on!! I have heard that there is some sequence on how to shut them off so if you have any info let me know thanks
Old 12-07-2008, 10:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Lights Out
To disable the daytime running lights only, you have to open the little cover that is inside the drivers door jam. Inside you will find a big heatsinc with two wires plugged into it. Just simply reach in and unplug it. Then turn your ignition on and see if your DRL's come on. They shouldnt.
Next to disable automatic headlights when it gets dark, you need to go to radioshack and buy a diode. I used this radio shack part number 1N4003, but i suppose any diode will work. I cant remember the exact specs for mine, but it is rated 200v peak, and 1 amp peak, so anything around these specs should be fine. Park your car in the sunlight and verify the headlights arent on. Once you have your diode, take off the little trim piece in the middle of your dash housing a sensor and a red LED light. Then unplug the sensor furthest towards the right (passenger side). Turn your car to run and see if your headlights are on. If they are, you have found the right sensor. Then form the diode leads to go into the plug that your just unplugged. plug it in there one way and turn your car on. the diode can only go in one way to work, so if the headlights are still on when you turn your car on, put it in the opposite way. One direction should work, and once you found it, just wrap some black electrical tape around it to make sure it doesnt contact any metel, and button it all back up in the dash.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-08-2008, 01:12 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Lights Out
if you dont wanna mess with wiring...you can also just remove the fuse for the DRL's. thats what i did. only downside to this is your auto on/off doesnt work so you gotta manually turn on your headlights at night.
Old 12-09-2008, 12:42 AM
tblake's Avatar
In God We Trust
Re: Lights Out
Funny, I tried that, but a relay went NUTS with that fuse out.
Old 12-09-2008, 11:03 AM
Re: Lights Out
thats weird...i have it done on both my GT and SE. on my GTX i actually did it the hard way like you suggested above
Old 12-10-2008, 06:33 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Lights Out
Yea, I yanked my fuse too with no problem. Interesting,,,,
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
