Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-07-2008, 06:17 AM
jamesmetairie jamesmetairie is offline
roation criss cross =no good.
i know some owners books says to criss/cross instead of just front to back. i also know that i,m looking at a set of nice michillins that are making alot of humming noises since they were criss/crossed. which why do you guys rotate tires?
Old 12-07-2008, 07:06 AM
CapriRacer CapriRacer is offline
Re: roation criss cross =no good.
Criss/cross rotation isn't causing the noise. The noise is being generated by irregular wear which in turn is being generated by misalignment. Rotating the tires is merely revealing the irregular wear pattern - moving irregularly worn tires from a non-noise producing position into a noise producing position.
Fix the alignment, and you'll stop generated more irregular wear. However, once the tires are irregularly worn, you can't go backwards (put rubber back on the tire). The best you can hope for is that the tires get a new wear pattern that erases the old wear pattern. At best, this may take some time. At worst, it may not happen at all.
Old 12-07-2008, 02:13 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
My summer tires are directional so I can't criss-cross rotate unless I was to dismount and remount the tires.
My winter tires are non-directional and since they are all the same, every time I put them on I have no clue what position the particular tire was in last. If they start to wear unevenly I'll be sure to mount the more worn ones in the positions less prone to wear on my car (the rear), but as of now, they seem to be wearing evenly.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-11-2008, 01:56 AM
blackm20i blackm20i is offline
i always criss cross cause my tires are non directional
